Presentation
The main focus of MODAL is to design generative models dealing with complex multivariate and/or heterogeneous data. Typical instances of such data are
- nominal covariables for the multivariate setting,
- and the combination of continuous and nominal variables for the heterogeneous setting.
From these generative models, a convenient and efficient statistical analysis remains to be carried out, leading to data analysis (visualization, clustering) and data learning (supervised and semi-supervised classification, density estimation).
Research Axis
MODAL is focused on generative models, that is models describing the generation process of data, unlike predictive models.
Generative models are of great interest. On the one hand, they are required in several statistical objectives such as clustering, semi-supervised classification, and density estimation, where predictive models are useless. On the other hand, these models enable data visualization. Indeed, they provide a full description of the data distribution, which gives access to several aspects of the data such as high density areas for instance.
In supervised classification, generative and predictive models directly compete with one another. However, the lack of flexibility of the generative approach, as opposed to the predictive one, is completely balanced by the use of model selection.
In addition, among generative approaches, parametric ones such as mixture models are preferred. Provided parameters are meaningful and parsimonious, mixture models allow valuable data interpretation.
